2004 Ford Taurus spark plug change & coolant exchange
2004 FORD TAURUS
80,000 MILES • 6 CYL • FWD • AUTOMATIC
ZACKRILEY
What items need to be removed to replace plugs in rear bank of 2004 Tauras Model SES, V6, DOHC Engine? And how is an anti-freeze change accomplished. Is it done by power flush, since there is no radiator cap. Thanks
Mar 22, 2009 at 6:24 AM
BILLYMAC
  • 2,204 POSTS
hi to remove the plugs if anything at all needs removed it will be the plantum.but with the right combo of tools you should be able to get them out maybe a better view from the bottom. the anti is normally replaced with a machine but not nessacary.there is a drain and it fills through the overflow tank. billymac
Mar 24, 2009 at 10:51 AM
13 JEROME
  • 7 POSTS
if your talking about sprak plugs. the mass flow intake needs to come off the big thing on top. just make sure to retieten to 35 pounds of pressure. that is the easyest way to do it. just make sure you do not damge the gasket. if you want to flush the raidator the best thing to do is go to the near Quaker state oil change place they will do it for you for around 35 dollars. and it saves you a big headache. hope i help any.
Mar 25, 2009 at 7:04 AM
