2004 Ford Taurus SERVICE ENGINE/CHECK ENGINE SOON LAMP
169,332 MILES • 6 CYL • 2WD • AUTOMATIC
MLWILSON77
THE LIGHT STAYS ON. AND, MY CAR WILL NOT START. THE CAR HS GAS AND THE READING FOR THE FLUIDS, BATTERY ETC.. READ GOOD. BUT FOR SOME REASON THE CAR WILL NOT START. AT FIRST, IT SEEMS TO BE SHOWING SIGNS AS IF IT WAS BATTERY ISSUES, I THOUGHT. BUT TRIED JUMPING BUT NOTHING. GOT BATTERY CHECK, AND IT HAS A FULL CHARGE. BUT THE CAR IS STILL NOT TURNING OVER. I'M HEARING A CLICKING NOISE WHEN TURNING THE KEY, BUT STILL NOTHING. COULD IT BE THE STARTER, THE FUSES. WHAT COULD BE THE CAUSE OF THIS.
Feb 10, 2010 at 5:09 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Feb 10, 2010 at 5:10 PM
