2004 Ford Taurus schreeching noise and whirring sound when
85,000 MILES • 6 CYL • FWD • AUTOMATIC
MDEWALKER
My car sometimes makes schreeching sound when trying to start. Sometimes it only takes 1 or 2 tries, today it took 7 tries before it actually turned over. I could hear whirring sound when I turned it off and tried again. Starter has been replaced. Now I'm thinking that it's the belt tensioner. The whirring sound is coming from the driver's side of the car. It's not a new problem but it's getting worse. I was also told that it could be dents in the flywheel. I'm not doing the work myself. I just want to know where to start
Dec 4, 2009 at 1:26 PM
BMRFIXIT
  • 19,053 POSTS
Remove starter an check the flywheel if flywheel OK replace starter again
belt or belt tensioner will not cause no start
Dec 4, 2009 at 2:09 PM
