2004 Ford Taurus Problems Starting
67,000 MILES • 6 CYL • 2WD • AUTOMATIC
ODDITIE21
Just recently the car has been having trouble starting. I turn the key and it tries to turn over - sometimes it succeeds, sometimes it doesn't. Whether it starts or not, for a few seconds after each attempt I hear a slight rattling noise that eventually stops. Once it does start it runs fine. This started right after I had two new tires put on and the alignment done, if that helps.
Jan 20, 2009 at 11:36 PM
JGAROFALO
  • 489 POSTS
This sounds like the starter drive is slipping. The tires and alignment are probably not related to the problem. I suggest that you have an experienced ear listen to it to confirm.
Jan 21, 2009 at 7:50 AM
