2004 Ford Taurus PCM
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
S.HARRISFUENTES
i WANT TO KNOW WHAT IS A PCM? MY CAR HAS A MESSAGE READING P0606 PCM PROCESSOR FAULT. hOW MUCH DOES IT COST TO REPAIR?
Jan 3, 2010 at 3:53 AM
MERLIN2021
  • 17,250 POSTS
PCM= Powertrain control module, this is THE main brain in the car, it controls the engine management, without it, the car wont run. It will require a Ford scan tool to reprogram the new PCM to work with your car's instrument cluster and security module.
It will be expensive! Probably in the order of 1500-2000 dollars. Call Ford!
Jan 3, 2010 at 3:59 AM
