2004 Ford Taurus not moving
SAMCL38
Transmission problem
2004 Ford Taurus Front Wheel Drive Automatic 78000 miles
Last night I drove my son back to college, everything was fine. On the way home I stopped and got gas. Exited the station, drove up to the light and waited to turn. When the light changed and I stepped on the gas the car would not move. I tried shifting into all the gears and nothing. The engine would rev and the shift will move up and down but it wont go into any gear. What could cause this? I am being told everything from the transmission, the linkage, the timing belt, etc.
Thank you
Feb 21, 2010 at 10:55 PM
2CARPRO JACK
  • 11,533 POSTS
Not the timing belt if the engien is runing.The trans is where you need to start.Have the PCM scanned to see if it has a solenoid in the trans that has shorted out, causing this or other throuble code that could lead to the fix
Feb 21, 2010 at 11:29 PM
