2004 Ford Taurus My car fuses go crazy....
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
JMACHUCA
i have a 2004 ford taurus..unfortunately i couldn't start it because the battery died. i checked both alternator and battery and they both good, but the car still doesn't start. the fuses just turn on and off like crazy underneath the dashboard and after a few seconds the dashboard display turns on and functions normally. but when i do that like two or three times, the display looks as if it has no battery when actually it has a new one...what could be wrong? also when the engine belt was taken off it fitted perfectly,now when we try to put it back on, the belt fits too big.(it is exactly as in the car manual's diagram) what could be wrong???
Apr 5, 2009 at 12:55 PM
MERLIN2021
  • 17,250 POSTS
Unfortunatly, if you have an instrument cluster problem, you need to have it scanned with a Ford Star tester. As for the belt, you ARE missing a pulley, There is a belt diagram under the hood.
Apr 8, 2009 at 12:11 AM
