2004 Ford Taurus Hesitation and Hiccup
95,000 MILES • 6 CYL • FWD • AUTOMATIC
DCWELL1
My 2004 Taurus SEL has what I can best describe as a hiccup when sitting at a red liget and shows signs of hesitation when I go to pull away. I have replaced the spark plugs, coils, manifold and EGR valve gaskets. Nto sure what more I should do. What should I try next? Thank you!
Jun 26, 2010 at 3:03 AM
BMRFIXIT
  • 19,053 POSTS
do you have a check engine light on ?
check fuel pressure
do a compression test
Jun 26, 2010 at 3:41 AM
DCWELL1
No check enging light but I will try the compression test and check the fuel pressure.
Thanks!
Jun 28, 2010 at 9:57 PM
