Recently, I have been having a problem with my car not starting up immediately, in other words, the motor will turn over, but not start. Been taking it to a Ford Authorized Dealer and they replaced the starter. Now, the engine light is on continually. Ford Dealer tells me it could be the PCM. They are running test and are going to re-program the computer module. If this doesn't work, they are going to have to replace the PCM at a charge of $500 to $600. Ford Dealer does not appear to know for sure, just trying things and costing me more money. Do you have any suggestions. Car running fine other than don't know if will start or not and engine light on all the time. What are your thoughts?
just went back to Ford dealer and they said it was the PCM and might need replacing if engine light comes back on. They reprogrammed the computer and said the following codes had showed up on the test , P0316,P0300,P0606. They reporgrammed computer and so far engine light has not come back on. They said if it did, then I would have to replace the PCM module. What do you think?
Sep 9, 2009 at 8:10 AM
