Is There A Special Tool Or Socket To Remove The Weird Bolt In The Middle To Expose All The Brake Mechanisms?
Oct 21, 2009 at 7:01 AM
BMRFIXIT
✓Experienced Mechanic
Remove brake drum?
If brake drum will not come off, remove access adjuster hole plug.
Using a screwdriver, move the brake shoe adjusting lever off the brake adjuster screw.
Move the adjustment tool handle downward to loosen the brake shoe adjusting screw nut.
