2004 Ford Taurus check engine light
112,000 MILES • 6 CYL • FWD • AUTOMATIC
JOSEPHR
  • 18 POSTS
I recently changed the spark plugs at 100k bought them from napa autp parts and the wires . after I changed them I misplaced one wire , then I fixed it but after that , the check engine light came on . I rest the computer then after driving came back on , i took it to the dealer they pluged it said catalytic converter , then I replaced it . after 4 or 5k the light came back on and it says catalytic converter . I replaced 3 oxygen sensors nothing happened . what could it be ? I thought maybe mass air flow sensor or the 3 converter ? help!
Nov 11, 2008 at 7:26 PM
BMRFIXIT
  • 19,053 POSTS
Lets start with what do you have for codes 1st?
also check for vacuum leaks
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 11, 2008 at 10:07 PM
