2004 Ford Taurus Car Stalls
87,472 MILES • 6 CYL • FWD • AUTOMATIC
BOWHNTR63
My 04 Taurus runs great but has a problem. For no reason it will just die. At an idle all electronics on the dash will go blank and the car will shut off. It starts immediatley with the first turn of the key. At freeway speed all electronics will will go blank and the car will stall, then restart and continue to go. The message board on the dash, (trip odom, miles to empty, mpg usage), always resets to default setting. The radio keeps its memory.
Feb 18, 2010 at 9:22 AM
BMRFIXIT
  • 19,053 POSTS
1st step disconnect battery terminals and check
Clean and tighten them, replace if corroded
Check alternator operation
Feb 18, 2010 at 10:15 AM
