2004 Ford Taurus Bad engnine performance
13,100 MILES • 6 CYL • 2WD • AUTOMATIC
MEMPHISTEN
My 2004 Ford Taurus misses badly and hesitates while accelarating when the air condition is on. When the air condition is not on, it runs fine. What could be causing this>
Jul 16, 2010 at 2:50 AM
KHLOW2008
  • 41,812 POSTS
Hi memphisten,
Thank you for the donation.
Symptoms indicates the engine is most probably misfiring.
When the A/C is not turned on, engine load is lesser therefore it does not misfire or the misfire could be too slight to be noticed. With the compressor running, the additional load is easily detected resulting in the misses and hesitation.
I would suggest checking the spark plugs, ignition coils and related parts.
Jul 16, 2010 at 4:04 AM
