2004 air conditioning pulley
171,000 MILES • 6 CYL • FWD • AUTOMATIC
SHELAGH
the air conditioning pulley ceased causing the serpentine belt to snap I was able to release the pulley and it now moves again the clutch is OK as far as I can tell but the pulley now moves more than it should and makes a rattling noise when the car is running. How much will it cost to repair or replace the pulley or I don't really use the air conditioning is there a way to bipass the air conditioner and if there is what size belt will I need.
Aug 2, 2008 at 11:11 AM
MERLIN2021
  • 17,250 POSTS
Buy a junkyard compressor with a good pulley and bearing, remove the 5/16th bolt on the front, pull the front piece off, this will expose a snap ring, remove it and note which way it comes off, it needs to go back on heads up, if you know what I mean, pull the pulley off, and install it on your compressor, this is the cheapest way out, and you don't even need to open the system!
Aug 2, 2008 at 11:18 AM
