2003 Ford Taurus won't move in drive or reverse
140,000 MILES • 6 CYL • FWD • AUTOMATIC
ELDON PURDY
transmission has been serviced every 40,000 miles. Fluid level is ok and is still bright red in color. The axles will not turn in park but when in drive or reverse their is tension against them and feel like they are snapped in properly. When I move the shifting level the unit on top of the transmission does move from each selection.
Jan 8, 2010 at 4:17 AM
BMRFIXIT
  • 19,053 POSTS
Check for tranny and PCM codes
suspect internal tranny failure
most common tranny pump
Jan 8, 2010 at 9:37 AM
