Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Body
Wiper
Fuse
2003 Ford Taurus Wipers
2003 FORD TAURUS
87,333 MILES • 6 CYL • FWD • AUTOMATIC
MLGOBLE
MEMBER
1 POST
What would cause a fuse to blow that operates my wipers/radio? In the 2 occassions prior, fluid either did not pump or barely came out.
Feb 2, 2009 at 5:33 AM
BMRFIXIT
Experienced Mechanic
If its blow just as you trying to use the wipers
suspect motor if its the washer fluid check and replace the pump
Feb 2, 2009 at 8:53 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
