2003 Ford Taurus Wipers
2003 FORD TAURUS
87,333 MILES • 6 CYL • FWD • AUTOMATIC
MLGOBLE
What would cause a fuse to blow that operates my wipers/radio? In the 2 occassions prior, fluid either did not pump or barely came out.
Feb 2, 2009 at 5:33 AM
BMRFIXIT
  • 19,053 POSTS
If its blow just as you trying to use the wipers
suspect motor if its the washer fluid check and replace the pump
Feb 2, 2009 at 8:53 AM
