2003 Ford Taurus Wheel Shake
95,000 MILES • 6 CYL • FWD • AUTOMATIC
GAYLENVQ
When I apply the brakes there is a shimmy in the steering wheel. I have had the tires balanced and the rotors replaced and resurfaced with no luck. The strange part is that it doesn't always shimmy....at times when I drive the car it brakes smooth and straight, other times when the brakes are applied lightly it shimmy's quite hard but other times when the brakes are applied a little firmer the seem fine.
what causes this? I'm thinking a proportioning valve but I'm shooting in the dark.
Aug 21, 2009 at 9:07 AM
BMRFIXIT
  • 19,053 POSTS
Have the front end check inner and outer tie rod ends one is bad if not both most common is the inner and some times it is very hard to detect
Aug 21, 2009 at 1:32 PM
GAYLENVQ
Thanks for the feedback. Would I see uneven tire wear from bad tie rod ends?
Aug 24, 2009 at 11:10 AM
