What is a transmission range sensor circuit and what does it do and how do you replace it
Mar 7, 2010 at 6:49 AM
BMRFIXIT
✓Experienced Mechanic
Its a neutral safety switch located on top of tranny
its job to prevent the starter from engaging and starting if the selector shift in any drive gears or reverse. It is where the shifter cable hooks up to the arm on the transmisison
