2003 Ford Taurus Taurus stalling/hesitating
50,000 MILES • 6 CYL • FWD • AUTOMATIC
STRIGOSE04
This car is hesitating when we press the gas pedal. Sometimes it stalls out. I'm afraid to drive the stupid thing b/c if I go to pull out in traffic, it doesn't go fast enough sometimes, then it will jerk like I suddenly floored it even though I've had the gas pedal down for 3-5 seconds. My husband had a tune-up and new mass air flow sensor put in. Apparantly something was wrong with the spark plugs b/c only 4/6 were firing and then he said there was metal on the mass air flow sensor. (This is what the mechanic told us) The problem was fixed... for a week maybe. Now we're back where we started, and the check engine light is on. I don't want to throw a ton of money into this car if all it's going to do is give us trouble. Thank you fro your time!
Dec 9, 2009 at 3:17 AM
BMRFIXIT
  • 19,053 POSTS
Checking it for codes should be the 1st step
I would suspect that you need a tune up
and also would check for a vacuum leaks
Dec 9, 2009 at 12:34 PM
