2003 Ford Taurus Sudden Neutral, has had electrical issues
72,000 MILES • 6 CYL • FWD • AUTOMATIC
THE OL' ABBOT
Car suddenly had no gear engagement, engine ran as normal, everything working. Occasionally have had problems with the ignition (unable to turn key, power locks not working sometimes). Had issues recently where engine would nearly shut off, but kick back in when gas pedal punched. Heard a "pop" each time. Had some loose fuses, seemed to clear that up. Could this be related to/caused by the transmission range sensor?
Mar 9, 2009 at 5:44 AM
JAMES W.
  • 2,394 POSTS
Fist, do you have a check engine light? Yes, it could be a sensor or pressure regulator in the transmission itself. I would recomend hooking the car to a diagnostic unit. This will tell you what's going on inside the trans electrically. Hope this helps.
Mar 9, 2009 at 6:07 AM
THE OL' ABBOT
No check engine light noted. Tried other gears, no response across the range
Mar 9, 2009 at 7:03 AM
JAMES W.
  • 2,394 POSTS
OK, There are many things that can cause what you describe. From low trans fluid, which I'm sure you've checked, to a broken pump, bad regulator valve, blown fuse(you might want to check fuses) to a bad torque converter. All these are on checkable without special equipment. I would recomend you get to a trans shop for diagnosis. I may be something simple, but without my actually seeing it, all I can do is quess, and quessing can get expensive. Wish I could do more for you.
Mar 9, 2009 at 8:47 AM
THE OL' ABBOT
thanks James - fuses are Ok, guess we're headed for the shop. Thanks for the help...
Mar 10, 2009 at 2:40 PM
JAMES W.
  • 2,394 POSTS
Let us know, if you would, what you find out so we can it on to others.
Mar 10, 2009 at 4:44 PM
