2003 Ford Taurus Stalls
116,000 MILES • 6 CYL • FWD • AUTOMATIC
CAR 321 HELP
Dear 2 Car Pros,
I have a 2003 Ford Taurus with about 116000 miles. At 105000 miles the plugs, plug wires and electronic coil were replaced. At about 110000 miles the TPS was replaced. Now when the car is idling only and the ac or defroster is turned the engine stalls. What would be causing this? Please advise. Thank you.
Apr 13, 2009 at 2:03 AM
BMRFIXIT
  • 19,053 POSTS
When defrost on AC will also engage so I would make sure AC system is functioning normal
AC compres. and clutch
check system pressure
check and replace idle air control valve
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 13, 2009 at 2:09 PM
