2003 Ford Taurus stalling
97,000 MILES • 6 CYL • 4WD • AUTOMATIC
MEME1
when i start my car sometimes it stalls and the oil light flashings. i already bought a new battery and they checked my alternator and said that was fine. my check engine light doesn't come on. what can it be?
Aug 14, 2008 at 5:48 PM
MERLIN2021
  • 17,250 POSTS
You may have a vacuum leak, get a can of spray gumout, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If that doesnt do it, you may need a new idle air control valve, it's bolted to the throttlebody
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
You can rent the test gauge at Autozone.
Aug 15, 2008 at 1:32 AM
