2003 Ford Taurus Runs Rough after starting warm engine
2003 FORD TAURUS
96,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVE.L
My 2003 Taurus 3.0 flex runs great until I shut off the engine and restart a few minutes later. It will surge, run rough, and sometimes stall but will restart. I have to power brake it when driving. After about 5 minutes of driving it will run great. The engine light is on and code p1633 is showing. I have replaced the PCM relay
Oct 10, 2010 at 10:56 AM
  • 110,244 POSTS
Have you checked the idle air control valve to see if it needs cleaned as well as the EGR? Also, are there any vacuum leaks?
Oct 11, 2010 at 12:30 AM
