2003 Ford Taurus Replacing wheel bolts or studs
130,134 MILES • 6 CYL • FWD • MANUAL
DRILLER24
Can you tell the proper way too replace my two broken studs on my right front tire. where to disconet from the brakes and any other suggestion you may have
Feb 19, 2008 at 11:56 AM
SERVICE WRITER
  • 9,123 POSTS
You need to pull the caliper off the bracket and rotor off of the hub. The broken studs can be driven inward popping them out. The new ones are installed from the rear and drwan in using a extra lug nut. Sometimes the passageway to get the studs into the hub is restricted and minor grinding of the stud base allows entry.
Feb 19, 2008 at 12:09 PM
