2003 Ford Taurus PLEASE HELP!
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
EDELPHIN
My car just started shutting off while driving, I lose all power (radio,a/c & dash lights will shut off) & the car feels like it going to stall out (I don't have to restart it, it just simply stalls)..it only happens for a brief second, I'm concerned that it may turn into a much bigger problem. Any ideas why it might be doing that?
Sep 13, 2010 at 1:41 PM
WRENCHTECH
  • 20,760 POSTS
Sounds like your losing a power supply somewhere. Check all you cables, fusible links and power feed wires, including the ignition switch plug.
Sep 13, 2010 at 1:46 PM
YOUKNOWMYNAME67
  • 25 POSTS
more then likely the negative battery terminal is loose check for tightness or see if it is stripped out
Sep 17, 2010 at 11:09 AM
