2003 Ford Taurus PCV hose
98,000 MILES • 6 CYL • FWD • AUTOMATIC
DUANE ROY
the check engine light came on and the car started running rough at a idle and i founf a vaccume leak at the pcv hose so i replaced the hose how do i get the check engine light to go off
Apr 26, 2010 at 6:52 PM
BMRFIXIT
  • 19,053 POSTS
Disconnect the battery should reset all codes and erase the PCM memory
Or use an OBDII reader to clear codes
Apr 26, 2010 at 11:26 PM
