2003 Ford Taurus Oil Leak
107,718 MILES • 6 CYL • FWD • AUTOMATIC
ZACHTEN
So I have a 2003 Ford Taurus Centennial. Nice car. Brand new transmission, tires; everything is good. Unfortunately, it is leaking oil, pretty bad. I have taken it to the mechanic and he replaced an oil pan gasket. Problem not fixed. Took the car back and he resealed it. Problem sitll not fixed. Do you have any idea what the problem could be or what I should do next? Thanks
Jan 18, 2009 at 4:29 AM
OBXAUTOMEDIC
  • 3,717 POSTS
[quote:ac46bdfdad="zachten"]Engine Mechanical problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic 107718 miles
So I have a 2003 Ford Taurus Centennial. Nice car. Brand new transmission, tires; everything is good. Unfortunately, it is leaking oil, pretty bad. I have taken it to the mechanic and he replaced an oil pan gasket. Problem not fixed. Took the car back and he resealed it. Problem sitll not fixed. Do you have any idea what the problem could be or what I should do next? Thanks[/quote:ac46bdfdad]
Has the front seal been looked at? If the under side is covered front to back in oil it could be the front seal.
If the under side is covered in oil front the back were the tranny and engine come together then it could be the rear seal leaking.
Also look at the center section of the engine if it is covered then it could be the Vavle Cover Gasket or even a Head Gasket.
Jan 18, 2009 at 4:42 AM
KEVIN12881
  • 336 POSTS
the mech should be able to find it, even if he has to put a dye in the oil.
