2003 Ford Taurus Inspection failed due to NO VOLTAGE readin
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
MANDAPARSO
My Ford Taurus recently failed the emissions testing because the computer would not connect to the car. The inspector said that the computer was reading NO Voltage and therefore could not perform a reading. The car runs fine, never had any mechanical problems. Engine light is not on. Only the brake light stays on all the time. I need to pass inspection. Any ideas how to go about finding the problem without paying someone to check the car out?
Apr 15, 2009 at 11:56 AM
BILLYMAC
  • 2,204 POSTS
hi does your check eng light come on when you turn your key on?
if not bulb may be out
check all fuses and ground wires .
Apr 15, 2009 at 12:00 PM
