2003 Ford Taurus Hub Cap problem
KID_JASON
Noises problem
2003 Ford Taurus 6 cyl Two Wheel Drive Automatic
On this car when i drive it the hup caps are hitting the wheel and making a really loud and annoying clacking sound on all 4s when i tighten down the plastic lugs over the real lugs they only tighten so far till they become loose again. I tried tightening them hand tight while i pushed in on it making it tight with the wheel and it worked till i hit the speed bump down the road. They are craked in where you put the wrench to tighten them.
Jul 19, 2010 at 3:52 PM
  • 31,937 POSTS
If the trims are cracking, you will be better off replacing them.
mark (mhpautos)
Jul 19, 2010 at 6:04 PM
