2003 Ford Taurus Heater not blowing
139,750 MILES • 6 CYL • 2WD • AUTOMATIC
LWAYMIRE
My Daughter has a 2003 Taurus. Her heater is not working. She said that at first it would come one some of the time but then stopped completely. I checked the fuses and they all seem to be good. I even changed the one for the blower just in case it was cracked and I could see it. The new fuse did not help.
The car runs great and has no other problems but ice is forming on the inside as we breath.
Jan 6, 2010 at 1:17 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. I'd have to check for voltage and ground at the blower motor connector. Voltage to the blower motor comes from the blower relay, in the junction box, under left side of dash.
Blower Motor, on and off, and different speeds, are controled on the ground circuit. I can't tell you exactly what the problem is, unless you can do some circuit testing.
Jan 6, 2010 at 2:24 AM
