2003 Ford Taurus Hard steering @ low speeds
BSCHURR
  • 45 POSTS
Steering problem
2003 Ford Taurus 6 cyl Two Wheel Drive Automatic
I checked the reservior & its circulating fluid, but the fluid is foaming & needs flushed. I jacked the front up & turned the wheels with the engine off & I can hear a metal on metal gringing noise coming from the rack. Do I have a bad rack? Is there any specifications on pump output pressure?
Apr 30, 2010 at 6:50 AM
BMRFIXIT
  • 19,053 POSTS
check front struts mounts and coil spring
May 2, 2010 at 11:22 PM
