2003 Ford Taurus Half of dashboard won't light up.
164,000 MILES • 6 CYL • FWD • AUTOMATIC
NKILDERRY
Half the dashboard won't light up when you turn the lights on. All the "idiot" lights work. The tack and half of the speedometer are dark and the other half is fine....just a light bulb or a fuse?
Feb 9, 2010 at 9:02 AM
BMRFIXIT
  • 19,053 POSTS
One fuse control all the dash lights if ½ out that will lead to assume that it’s a bulbs out
Remove cluster check and replace bulbs
Feb 9, 2010 at 10:30 AM
