2003 Ford Taurus flickering oil light at idle
2003 FORD TAURUS
24,658 MILES • 6 CYL • FWD • AUTOMATIC
BOOKKEEPER
fresh out of the ford sahop with new oil pan, oil filter,oil still flickering
Dec 30, 2007 at 1:39 PM
BMRFIXIT
  • 19,053 POSTS
[quote:46e4bc3141="bookkeeper"]Other Category problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic 24658 miles
fresh out of the ford sahop with new oil pan, oil filter,oil still flickering[/quote:46e4bc3141]
use what the car recommended for oil I thing 5 w20
and change the oil pressure switch
Dec 30, 2007 at 1:45 PM
TAURUSWHEEL
  • 718 POSTS
Has the pressure been checked with a mechanical gauge??? The dealer can do it, if not already been checked.. will at least verify or not correct oil pressure.. if okay maybe the electric sending unit or a ground issue with the bulb..
Dec 30, 2007 at 4:33 PM
