I have been having a problem with my car's engine stalling when I am idling at a stop sign or red light or such. I have checked into it on the internet and everything seems to say IAC Valve is probably the problem. The check engine light is on and when I had the local auto parts store run a check on it, all that came up was the O2 Sensors??? Could they really be the problem and not the IAC Valve? I don't want to spend money replacing parts that aren't causing a problem, but have been told I probably need my plugs changed too...and that THEY could be the problem...or the fuel pump??? Like I said, I don't want to replace parts that aren't the problem, but no one seems sure what the problem is! Can you help me???
Oct 14, 2010 at 8:08 PM
