2003 Ford Taurus engine miss
KID091
Engine Performance problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic 135k miles
I have a 2003 ford taurus with a 12 vlv engine and if I accelerate hard it'll cutout like the key was turned off and turned back on right away. I have 20 yrs in the auto parts field and have a little knowledge on how efi systems work so I did the normal things like changed the fuel filter, spark plugs and wires, air filter, still the same put a scanner on and no codes, fuel pressure gauge and fuel pressure maintained 40-45 psi, I then replaced cam sensor and no change but now it's stalling sometimes starts back up sometimes not and that was after highway driving it seems like if I drive without hard acceleration I never have a problem any ideas
Oct 24, 2010 at 5:22 AM
  • 75,988 POSTS
Clean the MAF sensor with an electronic cleaner CRC and also clean out the EGR valve, and test the throttle position sensor-
Oct 24, 2010 at 6:09 AM
