2003 Ford Taurus Driver Side Door Window Problem
86,000 MILES • 6 CYL • FWD • AUTOMATIC
JTCORBIN
My 03 Taurus has had a problem with the drivers side window for a few years now. The window will roll down but will not roll back up. The switch and motor have been checked and both are fine. I replaced the relay but no change. Does the Body COntrol Module control the window circuits?
Apr 21, 2009 at 6:24 AM
BMRFIXIT
  • 19,053 POSTS
Check the wiring
ground wire
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 22, 2009 at 2:04 PM
