2003 Ford Taurus door locks
2003 FORD TAURUS
136,000 MILES • 6 CYL • FWD • AUTOMATIC
TOOTE
Thr drivers side door lock switch will only lock and will not lock the passenger side works I switched the switch to the passengers side switch is good put the passenger side switch in drivers door still only locks will not unlock remote works Whats the course to follow way too many wires how do I locate right ones?
Mar 25, 2010 at 6:24 PM
BMRFIXIT
  • 19,053 POSTS
Replace the lock actuator as it is defective
Mar 25, 2010 at 6:37 PM
TOOTE
But the door locks and unlocks with the passenger side door switch and locks and unlocks with the remote so that would mean the acuator is working right?
Mar 25, 2010 at 7:08 PM
BMRFIXIT
  • 19,053 POSTS
Your 1st question was not clear
if its lock and doesn’t unlock
actuator is bad
but that’s a different story
check wiring harness in door jam
I will look up the wiring diagram for you if still need it
let me know
Mar 25, 2010 at 7:33 PM
TOOTE
Thanks hopefully the break will be obvious and the wires are color cordonated thanks for your help
Mar 26, 2010 at 5:31 AM
