crankshaft position sensor located
TJLAPKA
6 cyl Automatic 105000 miles
Where is the crankshaft position sensor located on a 2003 Ford Taurus?
Please help me! I love this site
Jul 31, 2010 at 4:46 AM
  • 55,781 POSTS
The engine crankshaft angle sensor is located down in front of the engine at the crankshaft level here is a guide to help you see what you are in for when doing the job and the location of the sensor in the diagrams below.
Check out the diagrams (Below)
Cheers, Ken
Jul 31, 2010 at 5:04 AM
NWENDTE9
I need to replace the crankshaft position sensor on my 2003 Ford Taurus. I know it should be simple to replace but lack all but the most basic knowledge of vehicle engines. What I need is a diagram or detailed instructions of where the crankshaft position sensor is located on the engine and how to replace it.
Thank you in advance for any help.
Feb 27, 2018 at 8:13 AM (Merged)
NWENDTE9
I was able to find the sensor. Thank you so much for your help!
  • 110,251 POSTS
Not a problem. Let us know if you have questions in the future.
TURFF
Electrical problem
2003 Ford Taurus 6 cyl Two Wheel Drive Automatic 72000 miles
where is the crankshaft sensor located
BMRFIXIT
  • 19,053 POSTS
On lower right front of engine
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_101.jpg
JACK CASS
I have a crank sensor issue with my 2002 Taurus, the 8th vin code digit is 2, any help would be appreciated, thank you.
LSWENSEN
Where do I find it? Do I need a hoist? Can I replace it myself?
Thank you, Larry
RIVERMIKERAT
  • 6,106 POSTS
Lower right front of the engine and yes, you can replace it yourself. It's usually just bolted in and has a wiring connector that needs to be disconnected.
