I took my car in and had it looked at after the light check engine light came on. The problem was the forth cylinder was mis-firing. I fixed the problem by replacing the spark plugs and spark plug wires. I then disconnected the battery thinking that this would reset the check engine like and it did. This only lasted for about 1 day. My question is "Is there a way to manually check what the engine code is for my car?
Jul 29, 2009 at 12:13 PM
