1997 Ford Taurus engine codes
MECH109
  • 1997 FORD TAURUS
  • 6 CYL
  • 141,000 MILES
I have a 97 taurus I have 4 engine code 141 161 340 453 first two o2 heater banks 1 n 2 next 1 cmp fault and last fuel tank pressure above max changed both o2 sensors and cam sensor no change. Any help would be great
Saturday, February 28th, 2009 AT 5:37 PM
JGAROFALO
  • 489 POSTS
You can have as many as 4 O2 sensors in your system, depending on the engine type. If you changed the wrong 2 sensors, the problem has not been repaired.
Also - make sure to check the power feed to the heated sensors. No power to the heaters will also generate codes.
The CMP code indicates a problem with the cam position sensor.
As a side note, with this number of codes, I would be more inclined to look for problems with the wire harness. You may have a spot rubbed through on other metal parts. Also check connectors from the sensors back to the processor. Also check your ground points. A bad ground can also generate "phantom" fault codes.
Thursday, March 5th, 2009 AT 5:56 PM
