2003 Ford Taurus Car Stalling
64,000 MILES • 6 CYL • FWD • AUTOMATIC
WAPAKMAN
Not totally sure these are related. The car will stall or attempt to stall and the warning lights will light up on display in either case. This seems to only occur when the AC is on. I have hooked gauges up and pressures are ok but then the cooling fans shut off and the high pressure will go to around 425psi before the fans come back on and everything levels out then it repeats. I am use to the fans being on all the time when ac is on in previous cars. Wondering if compressor is seizing up under this pressure or if something else is going on?
Jun 20, 2009 at 6:05 AM
BMRFIXIT
  • 19,053 POSTS
System may be over filled and or have a restriction in it
do a system code check
evacuate system replace orifice tube
Jun 20, 2009 at 10:19 AM
WAPAKMAN
Isnt over charged,,,have thought about the orfice tube but havent done it yet. Ive just never seen a fan set up that didnt stay on all the time when a/c was on.
Jun 21, 2009 at 5:54 AM
BMRFIXIT
  • 19,053 POSTS
Remote Climate Control Module Self-Test The remote climate control (RCC) module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns. The RCC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4 °-38 °C (40 °- 100 °F) when carrying out the self-test. If the temperature is not within the specified range, false in-car temperature sensor DTCs will be displayed. The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated. To enter the self-test, press the OFF and floor buttons simultaneously and then press the AUTO button within two seconds. The display will show a dashed line in the center of the climate control display window of the integrated control panel (ICP). The test may run as long as 30 seconds. Record all DTCs displayed. The self-test is completed when 888 appears in the center of the climate control display window of the ICP.
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_390.jpg
Jun 21, 2009 at 10:42 AM
WAPAKMAN
Thx again on the quick response. I have had the obdII checked and didnt know of the self test. My climate control is nothing like that. Has factory cd and just has the dials for the fan/temp/which ducts to blow from.
Jun 21, 2009 at 1:27 PM
