Not totally sure these are related. The car will stall or attempt to stall and the warning lights will light up on display in either case. This seems to only occur when the AC is on. I have hooked gauges up and pressures are ok but then the cooling fans shut off and the high pressure will go to around 425psi before the fans come back on and everything levels out then it repeats. I am use to the fans being on all the time when ac is on in previous cars. Wondering if compressor is seizing up under this pressure or if something else is going on?
Jun 20, 2009 at 6:05 AM
