2003 Ford Taurus cant start
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
CFOLSOM
My car was having a random misfire problem. My car would not start for a few hours after shutting it off. A problem that gradually got worse and now the car will not run at all.
I took the battery out and got it charged but the only response i get from turning the key is a click. I am at a loss of what to do.
Dec 5, 2009 at 2:28 PM
  • 75,988 POSTS
Load test the battery and double check for loose connections if okay your problem could be the starter, starter relay, transmission range switch and ignition switch
Dec 5, 2009 at 7:58 PM
