2003 Ford Taurus camshaft sensor
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMILE FORCIER
how do you install a camshaft sensor
Mar 25, 2010 at 10:08 AM
  • 75,988 POSTS
REMOVAL 1.Disconnect the battery ground cable.
https://images.2carpros.com/forum/automotive_pictures/12900_cs1_1.gif
2.Remove the Camshaft Position (CMP) sensor. 1 Remove the electrical connector. 2 Remove the bolt and the CMP sensor. INSTALLATION 1.To install, reverse the removal procedure. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Mar 25, 2010 at 10:17 AM
