brake pedal started going to the floor
90,000 MILES • 6 CYL • FWD • AUTOMATIC
36JOHN
The brake pedal started going to the floor( evidence of leakage from rear of master cylinder also), so i replaced the master cylinder( I bench bled it) The problem continued so I replaced it one more time. Same thing. When the engine is off I can pump the brakes up to a good height and pressure. As soon as the engine is stared the pedal falls to the floor. No leaks were detected around the wheels.
Feb 21, 2010 at 10:30 AM
BMRFIXIT
  • 19,053 POSTS
This is common when the ABS system needs to be bleed as well you will need a scanner that can open the ABS valves to allow the air out. Here is a guide as well.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Apr 5, 2021 at 5:02 AM
PPINNETTI
  • 7 POSTS
had to get the ABS valves opened worked great!
