2003 Ford Taurus blown head gasket
MESTILL
Engine Mechanical problem
2003 Ford Taurus 6 cyl Front Wheel Drive Automatic 90k miles
the car apparently got hot an seized up. after cooling off you can now turn the starter over, but it is obviously got a blown head gasket. My question is do you think the engine is trashed now?
Dec 31, 2008 at 6:39 AM
JGAROFALO
  • 489 POSTS
If teh engine got hot enough to siexe, there is likely damage to the crankshaft bearings and/or pistons. It may be rebuildable, but not economical to do so.
Once overheated to that extent, modern aluminum engines tend to warp. This creates untold problems later on, even after a repair.
The most economical solution would be to find a good used engine in a salvage yard.
Dec 31, 2008 at 9:32 AM
