2003 Ford Taurus
NANELLA
  • 2003 FORD TAURUS
Noises problem
2003 Ford Taurus Four Wheel Drive Automatic
Hello
I took my car in to get an oil change and tire rotation. I also received a service check, checking the hoses, etc. Now I hear a knocking noise coming from under the hood. Do u have any idea what could be causing the noise.
Thank you
Monday, February 9th, 2009 AT 9:31 AM
BILLYMAC
  • 2,204 POSTS
Hi nan, a knocking noise under the hood could be many things. But first check the oil make sure it is full. If oil is ok could be tensioner idler pulley.A/c pump internal engine noise. Good luck billymac
Monday, February 9th, 2009 AT 4:41 PM
