2002 Ford Taurus Speedometer Not Working
I'm in the process of installing a new stereo and can't get it to work. On top of this, now my speedometer is malfunctioning, my odometer, tripometer, dome lights, window and lock controls don't work...plus my bright lights indicator stays on and turns off when I actually turn on the brights. Any help would be greatly appreciated. This is not my first stereo install, but with that said, it is possible I accidentally had wires crossed...but I did have the negative terminal disconnected during install.
Mar 17, 2007 at 4:52 AM
Ok, so I found a bad fuse and that fixed just about everything...except my speedometer and odometer are still not working!
May 5, 2021 at 5:11 AM
Did you check the underhood fuse box also?
The speedo is electric, controlled by the VSS and pcm. Either the gauge, vehicle speed sensor, or wiring have a problem.
Good luck and lewt us know. :)
It was that fuse...after about a minute of driving everything was working fine again. I actually checked all the underhood fuses first, thinking it was something larger. Thanks for the help though, and I'll probably be back!!
Cool! thanxs for the update.
Suggested Repair
Check and replace the blown fuse that feeds the instrument cluster and related accessories after the stereo install. The speedometer and odometer recovered once that fuse was replaced and the vehicle was driven briefly.
Conversation Summary
After installing a stereo in a 2002 Ford Taurus, the owner lost the speedometer, odometer, trip meter, dome lights, and window and lock controls, and the high-beam indicator behaved incorrectly. A bad fuse restored most functions. The speedometer and odometer still failed at first, but both worked normally after about a minute of driving. The expert noted the electric speedometer is controlled by the vehicle speed sensor and PCM, so the gauge, sensor, or wiring could also be involved if the fuse did not resolve it.
