2002 Taurus alternator removal ?
TORGO2FAST4U
I have a 2002 Ford Taurus and I'm trying to repalce the alternator. The car has a 24v DOHC engine. All the bolts are out, wire harness is detached, the wire is unbolted. Now here's the problem... I can't fit the alternator between the Wheelwell and engine to lift it out. If I have to take it out though the bottom, what all do I have to remove?
Sep 26, 2007 at 2:26 PM
BLMO
  • 72 POSTS
You have to remove the crankshaft pulley.
Don't forget, it has a left hand thread.
You will also need to go under the car and find a rubber cap near the oil pan. It will give you access to the teeth of the flywheel. You will need to jam a screwdriver there to prevent the crankshaft from turning.
Don't you just love Fords???
Sep 28, 2007 at 1:21 PM
